silverbear
The Boy Who Never Grew Up
Got a helmet? Good deal that you got it going! I'd suggest that you walk the bike along for a hundred feet or so with the motor off and clutch in and watch the circuit the chain makes. Does the chain appear to move up and down or the rear sprocket the chain goes around does that seem to wobble a little? If either of these is the case then the rear sprocket may need some adjusting. Be careful with that chain tensioner, too, that it is tight enough to the frame to not get pulled into the spokes. Where is the chain rubbing and how badly?
It is worth taking the time to try to make things as right as you can in the beginning. You don't want to buy a new wheel right now and you sure as heck don't want to get hurt. Even a little fall at low speed can be bad news. Some of us have the scars to prove it.
Hey, you did good, girl. Woohoo!
SB
SB
