Here is the problem... Just about everyone with a suspended license that lives in a state where MABs require a license, will always want there to be a gray area, even when one doesn't exist. This is just my opinion. Unfortunately for those in states like OK and NJ, even electric bikes require a license.
Luckily for those in OK, they have a "restricted license",(not in NJ tho
) so you CAN get a license with a suspension... BUT!! you can ONLY use a car for back and forth to work. Problem solved!!
Sorry I didn't get back to you, I didn't see where you asked for the statute about what I was referring to.
It is Oklahoma Chapter 47 O.S. 1-104
It reads:
A. A bicycle is a device upon which any person or persons may ride, propelled solely by human power through a belt, chain, or gears, and having two or more wheels, excluding mopeds.
B. An electric-assisted bicycle is any bicycle with:
1. Two or three wheels; and
2. Fully operative pedals for human propulsion and equipped with an electric motor:
a. with a power output not to exceed one thousand (1,000) watts,
b. incapable of propelling the device at a speed of more than twenty (20) miles per hour on level ground, and,
c. incapable of further increasing the speed of the device when when human power alone is used to propel the device at a speed of twenty (20) miles per hour or more.
An electric-assisted bicycle shall meet the requirements of the Federal Motor Vehicle Safety Standards as set forth in federal regulations and shall operate in such a manner that the electric motor disengages or ceases to function when the brakes are applied.
C. A motorized bicycle is any bicycle having:
1. Fully operative pedals for propulsion by human power;
2. An automatic transmission; and
3. A combustion engine with a piston or rotor displacement of fifty cubic centimeters (50 cu cm)or less, regardless of the number of chambers in the engine, which is capable of propelling the bicycle at a maximum design speed of not more than thirty (30) miles per hour on level ground.
D. As used in this title, the term "bicycle" shall include tricycles, quadcycles, or similar human-powered devices, electric-assisted bicycles, and motorized bicycles unless otherwise specifically indicated.
It is the (D.) section I think might be able to help me here, unless I am just wishing it to say something it don't.
It seems to me that it says that my bicycle is classified as a bicycle, not a motored vehicle, or moped.
I couldn't find anything that said a license is required for a "bicycle", it may grasping at straws, but then I have nothing to lose by trying.
P.S. I tried checking into the restricted license, but because it was revoked by the court for non-payment, I was told they could not help me until the court released it.
