Which hub adapter for stock Cranbrook hub?
flatblack
Plan on ordering a MM adapter or something similar and not totally sure of which size to order. Anyone with a stock Cranbrook hub running a hub adapter? Thanks for the help!
No one has the Cranbook Manic Mechanic hub in stock
and MM is the only one that makes an adapter for it.
However you can order a custom sprocket adapter from MM.
The Cranbrook hubs varied in size quite a bit so you need to
very accurately measure your hub.
All the instructions are on their order page.
They come in different sizes? Mine uses the CB-110, built for the Worksman. No complaints here. Measure your hub and compare to the dimentions they offer- Piratecycles will list the dimentions each adaptor will accept. Chances are if your huffy has the 12 gauge spokes, the CB-110 will work for you.
the Old Sgt.
the Old Sgt.
Here is how to measure your hub.
MEASURE
