Bikeguy Joe
Wow fifty mph seems pretty fast for a beach cruiser. So if the less teeth on the sprocket the faster it goes. Which sprocket teeth count do you guys think is the best option in speed and torque?
The stock one- 44T.
If you have no hills and are under 200 pounds, a 40T would seem ideal.
I have a 36T going on the next build and I don't think I will see any higher that 40-43, since the CIF bicycle motors don't have enough tourque to pull any faster.
If you decrease the number of teeth on the rear sprocket, there will come a point of diminishing returns where the engine just won't pull any more....unless youare going down hill.
 )  THIS ONLY WORKS ONCE PER VEHICLE.  MY 49CC FRICTION DRIVE WITH 1 1/4 INCH DRIVE ROLLER DOES 35MPH WITH 180 LB DRIVER .  IT COULD USE A MUCH LARGER DRIVE ROLLER.  I GO 280 AND IT STARTS ME IN THE GRASS WITH A HALF TURN OF THE PEDDLES.  LOTS OF POWER.  BUT WHEN YOU GET TO 35 OR MORE I THINK THE WIND RESISTANCE IS A BIG PROBLEM !!!   WHAT IS THE CONSENSUS OF OPINION ON WIND RESISTANCE ??  RON
