Yes.Has anyone toyed with different carbs, porting, or pipes???
How would you raise the compression in a 4-stroke where the entire cylinder and head are cast into one as part of the crank case. Maybe Merlin the magician could do it using thicker valves or something............NOT! As BiMoPed said.....air filter, carb, cam and pipe upgrades.......same as it ever was.Yes.
Don't forget the Huasheng 49.4 cc Honda clone.
One more option is a free flowing air filter with
the standard carb.
SickBikeParts.com has an air filter upgrade.
AffordableGoKarts.com has a larger carb and air filter upgrade.
Also a reground cam.
A couple of exhaust systems.
The only company claiming upgraded porting on the Huasheng
motor or Honda is Dax with his Super Titan / Huasheng.
Dax claims 1/2 hp more with the Super Titan than the regular Titan
which he claims is accomplished by better porting and higher compression.
Personally I doubt these claims and Dax has never proven that his
$40 more expensive Super Titan has any porting or compression changes
over the regular Titan.
All experts including AGK I have talked to say there is really no way
to change the porting to improve over what Honda has designed.
You could raise the compression in these motors with a taller pistonHow would you raise the compression in a 4-stroke where the entire cylinder and head are cast into one as part of the crank case. Maybe Merlin the magician could do it using thicker valves or something............NOT! As BiMoPed said.....air filter, carb, cam and pipe upgrades.......same as it ever was.
And who makes these rods and pistons??? Nobody yet that I know of. And I'd like to see someone try to port one of these 50's seeing as how the head is one with the cylinder (and half of the crankcase). Unless they've got skilled mice machinistsYou could raise the compression in these motors with a taller piston
or longer rod???
Not easy to do though and probably not worth it.
Honda GXH 50 has higher compression than what is claimed for the
Huasheng 50 clone.
I have both motors and the finish on the Honda is much nicer than the
Huasheng. Just looking under the valve cover is amazing. The Huasheng
is very crudely finished compared to the Honda but they seem to be reliable.
I will take some comparison pics one day when I ain't so over my head with this race.
With a higher compression piston. We used to call them popups in the old days.How would you raise the compression in a 4-stroke where the entire cylinder and head are cast into one as part of the crank case. Maybe Merlin the magician could do it using thicker valves or something............NOT! As BiMoPed said.....air filter, carb, cam and pipe upgrades.......same as it ever was.
Flat top pistons rule....who's making high comp piston's for these little 50's? Wiseco pistons perhaps....I don't think so. If someone was making them, I'm sure AGK would be selling them.With a higher compression piston. We used to call them popups in the old days.
or longer rod???
Huasheng 50 clone.
How do washers under valve springs raise compression?i had good results by adding two washers under the valve springs. the timing gear survived after a full summer of riding non stop so i can say it safe to try.
works great on the Honda clone.
If you really increased the airflow you will need to rejet your carb.i just took a drill to the plastic sheild on my airfilter box helped a little and its free
They don't raise compression, they just raise the spring tension on the valves......it's not the same thing.How do washers under valve springs raise compression?
Has it ever been determined if it is the piston, longer connecting rod, or a smaller combustion chamber that is responsible for the increased compression on the Honda vs. the 142F? Has anyone tried using a honda con-rod on a huasheng for increased high-rpm longevity?
Therefore if the tolerances between the Honda and the Huasheng concerning the crankshaft, con-rod and wrist-pin are compatable, you could use the Honda's rod in the Huasheng for slightly more compression.Found some info on this that might shed some light:
Huasheng 142f: Bore: 41.8 Stroke:35.8---Actual Displacement: 49.1
Honda GXH 50 : Bore: 41.8 Stroke:36-----Actual Displacement: 49.4
Since the honda has a slightly longer stroke (by .2mm) it has a displacement advantage. This could be why they make a little bit more power. Also, if the motor castings are the same (and sleeve height/combustion chamber), this would account for the increase in compression.
