Re: Just bought 4 stroke Chinese frame mount kit
I had over 500 miles each on two different bushed engines and they were/are fine.
The rubber is the rag type rubber. Didn't know they even made a cheapy version of these things. I was told that the chunks cut out of one of them won't affect the setup when tightened down. I'll assume that with the metal half moon plates, one kit out floating around has 3 short ones and another kit has 2 longer ones instead of one kit having 5 total plates. I've been told 2 different stories on this matter. It does make sense that after you put the 3 plates, then you put the 2 longer ones over the seams in the 3 shorter ones for added rigidity. But who knows?Sorry, I thought you had a 2-stroke too, we'll still try to help where we can. I am courious about this engine also.
The mount for the wheel should be the same as the 2-stroke type, one thing I noticed this in your original post:
. Next, I find the sprocket kit only has 2 half moon clips when there should be 3. And one of the round rubber spacers had 2 big chunks gone out of it.
There are two diffrent types of plates for mounting the sprocket, one set is a 2-piece that is two half circles, and the other is a 3-piece in thirds. I have recieved kits with either of these types or both. When I can I use both layers pf plates layered so that there are no seams to the rubber and everything tightens down more evenly. For the rubber spacers, do you have the solid black rubber or are they cut out of old tires? The solid rubber is junk and crumbles over a short period of time, the tire ones are much more durable and I have never had a problem with them...Kelly
I'd probably have to have it done and I don't want to complicate things that much when I know there are probably piles of the engine mounts out there somewhere, it's just a matter of finding a dealer that will actually sell one. Some of the better known dealers don't even answer emails, so it's easy to get stuck fast.I think i would look at making one. If you can that is...
Hi Squid,I'd probably have to have it done and I don't want to complicate things that much when I know there are probably piles of the engine mounts out there somewhere, it's just a matter of finding a dealer that will actually sell one. Some of the better known dealers don't even answer emails, so it's easy to get stuck fast.
