What is a slant head
lmmacko
Could someone please tell a newbi what the difference is between a regualr, and a slant head engine is? Thanks.
Slant head refers to the spark plug's position in the cylinder head. The standard position will place the plug straight up and the slant angles the plug.
The theory is that angling the plug to the side of the combustion chamber allows for a better ignition of the fuel/air charge. Another benefit is vertical clearance of the spark plug to the bike frame when mounting the engine on some bikes.
Thanks a lot! :)
if you check the head upgrades from various aftermarket bike gurus you'll notice that the good ones have the plug TDC. (lol) but really, the plug on hi-pro heads Is most usually on top, centered above the piston. allowing the gasses to be ignited in a more uniform manner, producing a more powerful punch, rather than the mixture igniting on one side of the chamber and burning towards the other side. This may be of course, splitting **** hairs, but has a profound enough impact to be the motivation in building new jugtops. the main reason for the slanted plug (from what I have read from a few other credited know it all's) is compromise. It reduces overall engine height and allows for more mounting possibilities.
that and $1.50 will get you a cup of hot brown liquid...
A cylinder head that is slanted. LOL :p jk
The slant head was designed for frames that have tighter clearances and won't allow the straight head to clear. I have both a straight head and an angle-fire head they both run well and really offer no performance benefit over the other.
Just a quick question on this topic . I ordered a slanthead engine for a spare (it's still in the box) and the spark plug is in the front , angled toward the carb. I see pics going both ways. Does it matter?
No, if not for the fins, you could mount it sideways. I doubt anyone could tell the difference in performance between a TDc or slant head. I can't. But we're not talking about a vehicle you'd run at Talledega.
a "slant head" is what you get when your chain tensioner slips into your spokes and you flip over the bars, landing on your forehead in the street.
