blckwlfny1
Thanks guys. Does anyone know how much of a seal I should expect from the seals at the magneto case.
I recently decided to clean out the crank case from any possible offending manufacturing debris. After thouroughly washing out the warm soapy water I used "water displacer #40" (WD-40) for its intended purpose sloshed it around the lower and poured the extra out. When I later pulled off the magneto cover, I found a film of WD-40 in there. Does this necessarily mean the seal is bad and will not do what its supposed to? I don't want to go screwing with the crank or the magneto unless I absolutely have to as it could throw some other thing out of whack.
