Has anyone tried this trick?
Today I started my first build and I was looking at the grip shift grips and was thinking ?????
Why not reuse this as motor mounts for my engine? So I was able to on the front mount and the rear I had some pieces of rubber that worked better. I sliced them long and then cut out the middle.
Pictures have been provided for illustation..............
Where BE the pictures?
sounds great. everybody comes up with the solution to fit their frame and it's geometry.
I like using old leather belt, innertubes and the clamps that come with the kit on both the inside and outside of the tubing:
front
rear
jon
I used lead sheet front and rear, both sides of the tubes.
It works exceptionally well, I will do it to every bike I build from now on.
I used some 1/8" semi-soft vinyl I found at lowes. It's the stuff for walls that goes from the very bottom of the floor, up 5 inches or so. You see it alot in commercial buildings and its super strong. It was $1.86. But I've got a simplified friction rack mount so it was easy.
I guess I am not at all surprised to see how many of us have tried one thing or another to cut down the vibes.............
Great ideas everyone!
