I tried heater hose, and ot got kinfa crispy after a couple hrs run time.
Found some 3/4" hi-temp rubber aviation fire sleeve tubing in my" supplies"
I installed it with small hoseclamps. 2 hours later, no change.
Starting to suspect my muffler might have restrictions. Maybe at the inlet junction. Allready drilled the weld slag out of the outlet pipe and added the 5.5mm hole.
Seemed like the motor ran increasingly better as the heater hose gradualy burned a larger leak.
Still gonna do a compression test later today though.
