OK, I think I found the cause of my low performance.
After trying the 5.5 muffler hole, the extended spark plug, and drilling the air inlet holes to 8mm, with no change in performance, I had to pull the jug for a looksee.
I pulled the cylinder off today and found all 3 ring gaps in line, over the wristpin hole.
The top ring looks like it is seating pretty well. The second and third ring only show abouy 50% contact, no contact 1/4" each side of the gap. Might be inferior rings.The bore has crosshatch but not much and very ( mebbe too) smooth. Mebbe I shoulda honed it again.
I spaced the ring gaps and put it back together.It runs a lot better now, but mebbe still not right wit these crappy lookin rings.
Ran better after about 1 hr more time though. Might try a set of Solex rings if it don't get better with some more run time.
