What is this??????????????
Houseworth_t
I have bought two kits with this part in it and have no idea what it is for. It kind of looks like something for the coaster brake assembly maybe an extension which would be amazing that is exactly what i need. How did you set up your coaster brake assemble.
That's a special tool to remove the pinion gear off the crank, and I think it will also remove the clutch.
You thread the base part out side part of the tool all the way on. Then the center part of the tool the bolt part just tighten it and like magic it pulls the part off.
Yes, as stated above, it's a cheap chinese puller for your motor that it came with:D
Or if ya get really mad working on your motor, you can throw it really hard at the wall to relieve stress.....it's really a dual purpose puller, use it carefully :D
If i knew how to delete this post so no one waists their time looking here i would. but maybe someone else will learn this too.
Was a good question House. I'm sure it will help some one else and pics always speak volumes.
