skitchfish
Hey Heaven,
I sure could be way wrong here but I nutted the steer tube down on the headset just like normal bicycle. I did this with the aluminum triple tree removed. I then used a thin nut over the triple tree. The triple tree rides over the headset nut, not the top of the bearing.
My application is surely different than yours because I am not installing it on a whizzer, but an older roadmaster. This appears to work smoothly and safely. If someone knows differently I would appreciate the input. In my case I thought the fork fit perfectly in length and diameter with 1 5/16 bearing cups. There is just enough threads coming through the aluminum triple tree to put a thin nut over it.
The old goose neck would fit down that whole also but I am choosing to use the handle bar clamps which brings me to asking you a favor. Would you please measure your new handle bar diameter at the grip and where they attach at the triple tree clamp. It looks like I could use 7/8" motorcycle bars but am not sure. I would like to know if the bars that are supposed to fit it are swelled and knurled where they attach to clamp. Thanks for all the help.
