dyno roadster build
stugots
This is my second bike I built, one of the pics shows a 25 year old green bike thats my every day rider had it 4 years now and still runs like a top, I decided to build bike 2, I took a brand new motorcycle tank took out 6 inches, had to remove/replace the main backbone of the bike with a thicker ga. and bent to fit contour of the gas tank also at the back wheel I placed gussets for a little added strength.All cables run through the handlebars and backbone bar, first time out runs great.I wanted a clean smooth look to this build.I'm selling this bike to build bike 3, more of racey type the pic shows the tank that i built to for another stretched out rider.
WOW thats a nice bike. The tank is amazing. The lack of all the cables showing is the way to go. Post some more pictures for us to view.
BTW DYNO's RULE...
ccc
That looks awesome! (^)
Keep an eye on the bottom frame tube right where the front motor mount is welded... they like to crack right there! :(
Would welding a piece of iron along the bottom fix that problem?
Terry
What I've done to fix the problem, is to weld a small gusset plate between the the two.
Here's a pic of one of my customized Felt ElGuapo frames... If you look close you can see it.
