nidyanazo
Just thought I'd write a warm up how to for these hi-compression, hi-performance motors.
Start the engine by putting the choke on full, and opening the throttle about 20%.
As soon as the engine starts, after about 10 seconds close the choke to normal running position, and keep the idle up using the throttle. Otherwise the plug can foul if you use the choke too long.
Blip the throttle up and down while maintaining a fast idle speed.
As the engine comes up to temp keep pressing your hand on the cylinder head cooling fins to check the how warm it's getting.
As you rev the engine notice the blue smoke from the muffler.
When the engine is warm you will not be able to hold your hand on the cooling fins for 5 seconds, and the blue smoke will stop. You may still see a faint trace of smoke of course (they arn't called two smokes for nuthin')
Two strokes are lubricated by the oil in the fuel, so you must rev it to get the oil to move. Idling does not lubricate well.
Failure to warm up properly can result in a cold seize, or scoring of the cylinder walls.
This process takes AT LEAST 5 minutes, but up to 10+mins in colder climates.
Your motor will last longer and perform better by doing this.
