http://motorbicycling.com/f23/super-titan-15614.htmlHow is the Super different from the regular version?
What does the manufacturer do to the Super to make it super?
Better carb?
Porting?
Is it still the same displacement?
Exactly what changes have been made that makes 1/2 HP more?The Super Titan "Titan Supers" are in. These are a souped up Version of the TITAN XC50. These Factory Souped up Titans make 1/2 hp more than standard Titan and also come with 1 year Warranty. The Standard Titans are great and have acquired a Name and excellent reputation world wide. I expect the Super Titan XC50S will do the same. I am not completely sure what the factory has done to make them so powerful and I could only guess since I have not had one apart. They are telling me that Stroke and bore have been altered as well as compression. All these changes add up to more Power !!!
Engine Type Air-cooled 4-stroke OHV
Bore x Stroke 41.8 X 36 mm
Displacement 49.4 cm3
Net Power Output* 2.1 HP (1.6 kW) @ 7,000 rpm
Net Torque 2.0 lb-ft (2.7 Nm) @ 4,500 rpm
PTO Shaft Rotation Counterclockwise (from PTO shaft side)
Compression Ratio 8.0:1
You did not answer any of the questions about the Super Titans engine specs?The Honda and Titan Standard are rated at 1.8kw 2.5ps. honda gxh50, gxh50k1, 2.5hp (50cc) engine specifications . That is the same as 2.5hp at 7000rpm they are posting. If you do the math, you get 2.41hp. So.. I am not sure what is going on there.. For increased reliability, Addtional oiling grooves have been added in critical areas as well. These engines are so reliable , I have not had to take one apart yet to see all the internal differences there are. Displacement Spec is the same. In a drag race, the Super Titan will run away from the Honda GXH50. Enjoy the ride...
The question was not about the Honda GXH50When I get a chance, I will procure and then post more detailed specs.. I can tell you this.. the Super Titan XC50S will run away from the GXH50 .. It says.. Bye bye ...... Enjoy the ride..
So you are saying that higher compression and better porting enable yourHi skyl4rk ,
Porting is better and compression is bumped up. Also has additional oiling grooves. I can tell you this.. It will out run HONDA GXH50. Super Titan is Super !!! Enjoy the ride..
I do not have any more specs or Details to offer other than those specs posted on my website.
4 stroke ohv
1cyl
48.8cc
3hp
2.75 Nm torque
Max RPM 7500
Air Cooled
CDI ignition
length 274mm
Width 226mm
Height 354mm
Weight 12 lbs
If these specs do not suffice, you can always call me at 303-459-2780. That is.. If you are serious. Call me Scott.. That way we can... Talk..... And with VOIP and other mediums of propagation, the talk will be as you put it.. Cheap.. lol
I am seriously curious as to these claims....that is all. I have a source for not so Super Titan's, so I'll spare you the expense of cheap talk until I see what these super engines do with my own two eyes, but thanks just the same.I do not have any more specs or Details to offer other than those specs posted on my website.
4 stroke ohv
1cyl
48.8cc
3hp
2.75 Nm torque
Max RPM 7500
Air Cooled
CDI ignition
length 274mm
Width 226mm
Height 354mm
Weight 12 lbs
Hi BiMoPed,I want to upgrade my 1.6 HP Robin Subaru 35 cc to the most powerful 50 cc 4 stroke
that I can get for my friction drive.
Thanks for your answers
