Thanks Bill, taken er fer a spin this mornin....the maiden voyage so too speaklookin good Scotto![]()
![rotfl rotfl rotfl](https://motorbicycling.com/images/smilies/rotfl.gif)
My bad one is trying to start my 99 Whizzer with the kill switch off. Once I even pushed it home, took off the tank, checked the wiring & replaced the coil ,then the CDI. Finally a friend was there & said "isn't this kill switch in the off position".Gluekill,
Sometimes it is the simplest things which hang you up. I recall a time when I was riding along with my two stroke and the engine sputtered a bit and died. Nothing I could do to get it started. I checked wires from the magneto, kill switch, CDI wire snugness,fuel line to see if gas was flowing... that was it! Fuel. Must be something plugging the line at the gas tank since nothing was flowing to the fuel filter.
Then I thought to open the gas cap for a look
and realized I had run out of gas. Duhhh.
So glad you got that sorted out. Good luck riding today... stay safe.
SB
Is your Grubee G4 4 stroke still running?Thanks Bill, taken er fer a spin this mornin....the maiden voyage so too speak![]()
Of course the 4G 4-stroke is still running like a champ...I ride it everyday. Seeing as how the EZM is still in the build, it's impossible to compare the two. When I finish the BB and cranks, get the heavy duty rear wheel, get some brakes and tidy up all the loose ends and wiring I'll be able to give it some proper riding time. Until then, stay tuned....cheers!Is your Grubee G4 4 stroke still running?
How does your new EZ motorbike Q Matic compare to your G 4?
Thanks silverbear (and Bill), the sprocket is the stock one off of my other 4-stroke....it's 2 teeth bigger (38t) than the original off of this bike....I had to do a little fabrication to make it work of course. I used the 206mm wide cartridge bottom bracket from SBP.....barely clears with the stock cranks.Scotto,
That's a good looking bike and a nice install. Fits right in there. And you didn't have to change the pedal crank! Is the Pedal sprocket stock, too? I like it.
SB
