Yeah thats a few teeth short.
Maybe? Maybe Not? The 4G drive is adjustable for C to C distance of the two pulleys using the offset rear shaft adjuster. Using the calculators on the Pfeifer industries web site here are the following C to C distance for the most common belts on either side of the speced 570mm. A 565mm belt needs 4.52 inches C to C. A 580 mm belt needs 4.87 inches C to C. Measure the range of Center to Center using the adjuster at its closest and longest settings. Maybe a 565 will work?
ocscully
