That's a good deal. Some people can't seem to fit them, and others have no problem. But when they do get'em on they can't believe they didn't do it sooner. I don't have one yet, but use the 'Google search' at the top of the page for 'Grubee Pipe' There's lots of info around, like this thread:
http://motorbicycling.com/showthread.php?t=21489
and this one:
http://motorbicycling.com/showthread.php?p=117568
Have a click around, gl.
If it's local and you can take it back no charge try it, what the heck right?
Otherwise you have lots of issues to deal with.
Naming the bike don't help much for easy answers, pics of your build with motor in do.
Yes, I've used one and am still using it. It improves the power througout the powerband with no hard hits of power anywhere per se. I can't tell you the RPM's for sure as I wasn't running a tach, but you do get a bit more top-end with it. I paid $50 for mine and it bolted right up.
Also, it does come very close to touching the front tire of my 2-stroke cruiser w/66cc HT engine, and your left foot as well if you're not careful! Here's some pics:
Cheers![]()
Perfect my brotha exactly what I was looking for, i plan on wrapping in black exahaust tape (stealth and leg burn pretection. Where did you purchase yours? great bike btw what top soeeds you hitting?
Ya I'm not allowed to say helyel lol, tnaks for telling me now you have tired it and with a 41 tooth 45mph? That what I'm looking for maby a dellorto carb instead though, cns seems sketchy even over stock, you have any other mods besids maby a plug and porting? What about loudness is it that pop pop pop sound or ditbike style?
Kayper,
I use the Grubee pipes all the time with good results. I do rework the flange and flange angle for better fit. That pipe you show looks different from the Grubee fat cat. It looks narrower and has a different exhaust tip.. Do you have a link so I can check it out a little more?
Pat
Most of what you read on here will tell you that for best results the exhaust pipe should be 11-12" before the expansion chamber.
Makes me think twice about this and lean more toward the SBP model for $65 (that's the price, right?). I got an entire exhaust from a CAG pocket bike, on eBay, and have been wondering if the expansion chamber is large enough to make much difference on a 66cc engine.
Anybody have experience with using a pocket bike exhaust on these?
The flange is the same size as stock, but I'll have to cut, bend and weld the pipe to make a custom fit to my engine and I'm wondering if the work would be worth it...
(Smiles) very nice ;-}And Mr. KC Vale....notice no chain tensioners on either chain, just a bracket on the pedal drive side...
That Xpipe looks a bit cumbersome, but effective.
You may have issues with a one-piece pedal crank however. They tend to be pretty narrow.
Are you planning to use gears and Jackshaft it?
Cranks won't matter then, the kit comes with a new 3-piece crank.
Gears are your friend but like you said, if money is the main issue you can forget that.
