jasonh
So I've currently got no spark. I did a test on my CDI that should have told me whether or not it was bad. Test showed mine was bad. I was just wondering if someone with a working CDI could run this test just to make sure my test even works at all.
Basically you need a ~6v source. I used 4xAAAs wired in series (because that's what I had handy), but you could use one of those big 6v batteries, a 6v ac/dc adapter, even a 9v battery should work.
So here's what you should do:
connect the black wire to the (-) on the battery.
Ground the spark plug threads to the (-) on the battery.
Tap the blue wire on the (+) of the battery.
Each time you touch the blue wire to the battery, you should get a spark. I did not get a spark.
Someone want to help out and verify these results? If it works, this would be an easy way to test your CDI.
Thanks
Thanks
