GeneFiorot
Manufacturers are know to use different hubs from time to time. As in the Jaguar that killed the kit idea for Jim. To be sure always measure.
Yephi patrick,
yes, that gap, ok, no need.
Is the adapter actually squeezing around the hub for a secure fit?
I think the cranbrooks came with different hubs???...??? why is there a cranbrook hub measurement?
I would bolt it up to your hub and be on your way. Just make sure to tighten it evenly so the gap is the same on both sides.it be a shamino falcon measurement ONLY?
Im a little confused.
Yep
Pat
Cranbrook Sprocket Install.
??? Help ........ PLEASE ASSIST ???
Im having problems mounting the ragmount sprocket:
a. rubber discs seem too thick
b. rubber discs and metal banana attachers dont all align up,
(hitting part of hub/ sprocket too)
c. sprocket brake bar seems like it will hit the bolt heads when installed.
(some posted no mod./bending of cb arm required)
1. (went to a machine shop, and he wanted $45.00 to $70.00 to increase the sprocket hole size on 2 sprockets. ---> At this point, that option is cost prohibitive, knowing you can get a adapter, sprocket for $50.00 from PIRATE)
2.PIRATE is out of stock...it really does sound too painfully familiar.
--->JIIIIIIM! get your product out to Justin!
I've decided to either not reinstall dust cap,OR install it if it fits. (i dont want to grind down the dust cap.)
Im getting a little bit frazzled.
Sprocket concave or convex side out, whatever works.
Can anyone share several detailed PICS please of installed sprocket? and go over it with me?
I feel so inept, so stupid right now.
The instructions say 2 hours total build time - UNREAL...
I spent 4 "dry fitting"sprocket and I didn't even install a single thing!!! (not to mention the dozens of hours online trying to research the build.)
Sorry if i'm ranting.
Thanks for all your help in advance Guys/Gals.![]()
Mine uses the cb-110 adaapter. Others have a smaller diameter. Read along in this thread and you will see the other cranbrook hub diameter then check if its the same size as the modus adapter also in this thread.The cranbrook uses the cb110 hub adapter or the modus hub adapter?
? fat daddy ?
You JUST bought your Cranny from Wally 2 weeks ago?
And bought the adapter from Justin at PIRATE?
Works like a champ?
HOW did you get the part(s)? Sprocket too?
They are out of stock!
Youll have to call the hub vendor and ask them to measure it for you.
Pirate lists the sprocket for the Manic adapter as fitting a #415 chain only.
Does anyone here know, if I buy a #415 chain from a local motorcycle parts store, if the chain is the same and will it fit the Manic sprocket?
