robin
Has anyone considered the Tomos Revival a cute motorcycle with pedals a throw back to the 50's mopeds spoked wheels--advantages $1695 U.S. --2 stroke -2 gears smaller stronger wheel top speed 45 mph--also has a 70cc upgrade with tuned pipe for you speedsters --one year warrantee--no screwing around to keep it running--iam seriously considering this one !
Technical Info
Engine Type: 49cc air cooled, single cylinder-2 stroke
Bore x Stroke: 38.0mm x 43-Omm
Compression Ratio: 10.0:1
Carburetion: 14mm Dell'Orto PHVA
Ignition: CDI
Transmission: 2-speed, automatic clutch
Final Drive: Chain (103 rollers)
Front Suspension: Telescopic fork
Rear Suspension: Swing arm with two shocks
Front Brake: Disc (230mm)
Rear Brake: Drum (105mm)
Front Tire: 2.25-17
Rear Tire: 3.25-16
Wheelbase: 47"
Overall Length: 72"
Min. Ground Clearance: 12"
Seat Height: 31'
Dry Weight: 143lbs
Fuel Capacity: 0.92 gallons, including 0.13 reserve
Oil Tank Capacity: 0.2 gallon
Carrying Capacity: 300lbs
Fuel Consumption: 100mpg
Technical Info
Ignition: CDI
Front Tire: 2.25-17
Rear Tire: 3.25-16
Wheelbase: 47"
Overall Length: 72"
Seat Height: 31'
Dry Weight: 143lbs
