Tomos Revival ??
Discussion in 'Motorized Bicycle General Discussion' started by robin, Jun 21, 2010.
  1. robin
    robin Member
    Nov 15, 2008
    615
    Has anyone considered the Tomos Revival a cute motorcycle with pedals a throw back to the 50's mopeds spoked wheels--advantages $1695 U.S. --2 stroke -2 gears smaller stronger wheel top speed 45 mph--also has a 70cc upgrade with tuned pipe for you speedsters --one year warrantee--no screwing around to keep it running--iam seriously considering this one !
    Technical Info
    Engine Type: 49cc air cooled, single cylinder-2 stroke
    Bore x Stroke: 38.0mm x 43-Omm
    Compression Ratio: 10.0:1
    Carburetion: 14mm Dell'Orto PHVA
    Ignition: CDI
    Transmission: 2-speed, automatic clutch
    Final Drive: Chain (103 rollers)
    Front Suspension: Telescopic fork
    Rear Suspension: Swing arm with two shocks
    Front Brake: Disc (230mm)
    Rear Brake: Drum (105mm)
    Front Tire: 2.25-17
    Rear Tire: 3.25-16
    Wheelbase: 47"
    Overall Length: 72"
    Min. Ground Clearance: 12"
    Seat Height: 31'
    Dry Weight: 143lbs
    Fuel Capacity: 0.92 gallons, including 0.13 reserve
    Oil Tank Capacity: 0.2 gallon
    Carrying Capacity: 300lbs
    Fuel Consumption: 100mpg
  2. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    Sounds boring. :p
  3. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    sounds like a pocket bike powered moped if the add is recent
