Tulsacruiser
Ok whats the deal I went to the parts store and picked up a NGK B6HS cause my old plug is fouled, so I screwed the new plug into the head and now the Plug wire will not fit?? Do you need a different plug wire with the NGK's?
Can you unscrew the top nub of the spark plug with a pliers and make it look like the other oneexchange tops
Does the two spark plugs look the same on the top end?or does one have threads like the little cap of the spk.plug was screwed off,,,Little metal cap on top of the spark plug does it un-screw?
