I`m running the SPEED carb. with great results and no issues at all.... Straight from the mail box to the motor and runs sweet.... It`s a big PERFOMANCE carb. but it`s handling my motor with all the stuff I`ve done to it, billet head, porting, ect.ect.ect.....
I wondered the same....The slide is bigger, the throat is 3mm bigger, it has another shutoff valve, drainable float bowl...For $25 I figured I`d give it a try....It works pretty dang good for me....No jetting change, just put it on and hauled ass.....But still no pilot jets.....
X2....Thats why I didn`t go to the CNS carb....I did open up the ports a little and a nice exh. system and the stock carb. was holding it`s own at the time....The Speedway carb. isn`t overly perf. orientated and didn`t have to fiddle with it much at all....First question you should ask yourself is am i getting the most out of the carb im using.
A bigger carb wont fix 4 stroking it will make it worse, An 18, 19mm or 21mm?? carb would be worse on a std engine exhaust setup. If you do buy a "performance carb" or really just a bigger carb 99.9% of the time you will need to rejet it.
