You should practice using the front brake! As with all two wheeled vehicles, the front brake is responsible for 90% of the total stopping power!
Get used to it, learn it, love it... That front brake is your best friend!
I learned this on a 600cc sport bike a long time ago. I was in a jam and had to stop quickly. I was afraid of the front brake too and I locked up the rear tire. The rear tire locked up and went side to side. I almost laid it down. Luckily I stopped in time. From then on I learned to use my front brake 90% and everything is good. The only time I would worry about using too much front brake is if you are turning hard and the ground is wet.
If you have really good brakes on a conventional bicycle and you grab the front only and brake too hard you can do an endo and wind up with a face plant. Don't ask me how I know.
I can't help but believe that you did something very wrong...
I've ridden bicycles & motorcycles like a madman ever since I was a small child; & never once have I (or anyone else that I know) gone over the bars from using the front brake!
It's statements like that that keep nubees from learning the proper way to use the brakes!
I did not go over the bars I made a panic stop because of a dog right in front of me and locked the front wheel with the front brake and the bike rotated around the front axle resulting in a ride on the pavement. And if you will reread the post I said the front only. You must not have had very good brakes. I did not say to not use the front brakes because they are the most important part of braking just do not overdo it. I have seen crotch rockets with the rear wheel a foot off the ground because of braking.
lets all just play nice.......
While it's true the front brake is responsible for a hugely disproportionate amount of the stopping power, this is only applicable in ideal riding conditions - both brakes used in unison & varying amounts of pressure (depending on conditions) is the proper way to brake... that is ofc why there's two brakes and each with independent control. As a year-round rider, this is a lesson I've learned well.
When it's nice out and the pavement is clean and dry - sure, I only use the front brake (mostly jus' sheer laziness)... but if I'm dangerously close to a lockup and/or there's even a little sand you better believe that rear brake comes into play. Adding stability, even if the braking power of the rear is a mere 10-20 percent - that's more than what you'd have by not using it. Assuming a panic stop, should the front start to get squirrely it's nice to already be crankin' down the rear when you lighten up the front.
I'm a devout proponent of front brake use - but don't get the idea that the rear one has no "influence" at all, the only time that would be true is if the rear wheel actually did come off the ground and if that's the case - it'd hafta be almost perfect conditions & improper weight placement... a fairly unusual occurrence unless done on purpose.
Best bet? Practice using both while remembering the front gives you the stop & the rear gives ya stability
I've upgraded to disc brakes on my bike, also thanks to SBP's shift kit. The change-over made a MAJOR difference in stopping power from the calipers I had. Also, I use a dual brake lever and pulling it to stop with both brakes is almost effortless.
Since my frame and forks didn't have mountings for disc brakes I bought 2 mounting adapters from these guys Choppersus.com Brake-Parts-Hardware/
NOTE: If you use these adapters you'll need 180 mm rotors. I had to do a little cutting on my stretch frame to get the rear adapter to fit but shouldn't be a problem with a regular cruiser frame. Also, to mount on front forks just grind off the tab that fits in the axel slot.
View attachment 23471 View attachment 23473 View attachment 23472
I did read what you said... that's why I said what I said.
Next... I've ridden bikes with good brakes, bad brakes, the best brakes & even no brakes; but never went over the bars because of the brakes...
& last... those crotch rockets do wheel stands because they are trying to! I know for a fact that you can lock the front wheel on them & still keep the rear grounded!
