grouchyolfart, big brown is well named. We have to pay a "border broker" fee based on what the item is worth. I ask if they can send it by mail. No fees and just about as fast.
Steve.
Steve.
Was thinking of that too. I think I'll just pick at it and keep an eye out for deals. I replied to an ad for a wrecked electric scooter last night. The owner doesn't seem to know anything about what's under the plastic, so I'll probably have to go have a look see.drive over and bring it back???
NO it wouldn't. You can ALWAYS over volt , not "overamp" - which is happening when using 48v motor with 36 V pack. For the gazilionth time : Volt = speed , Amps = acceleration (torque).Pardon me if this question has an obvious answer, but would a motor rated at 48V produce similar speed and torque at 36V as a motor rated at 24 to 36V? Just thinking if I do buy a new motor that I might get something that can handle a battery upgrade at a future date. You know; when lifepo4 batteries come on sale at dollarama
Makes sense. The 48V controller will work ok with 36V assuming it can handle the watts, right?NO it wouldn't. You can ALWAYS over volt , not "overamp" - which is happening when using 48v motor with 36 V pack. For the gazilionth time : Volt = speed , Amps = acceleration (torque).
So buy 36 V motor - you can add more Volts later (faster , better range).
Instructions??? Heck no. Bought the kit used. Good thing for me I had already worked with a Currie system so I had the basic knowledge for assembly. Only thing different is that these hub motors can run backwards if not wired correctly and draw big amps, initially. I've burned out my share of 40 amp fuses when I used the wrong wiring harness on several occasions. Senior moments. <sigh>There were instructions weren't they (about controller , I mean)? Controller can be fixed (for example , by TV repair guy) and your "learning curve" has just gone waaay up I've messed up few things in my life too (and that was the stuff I know about), if that makes you feel better. As the bumper sticker says : S..t happens !
Me think it's time to just order a bunch of 36 volt controllers. I just burned out my spare.Watch out on the amp rating of the on/off switch (lamp switch isn't for the job, it could melt).
As for the repairs of the controller, I just mentioned one option out of top of my mind. Anyone who deals with electronics can repair it (unless leads on the circuit board had it), simply by replacing burnt components by the same/similar ones or upgrading it for right voltage (36 V). If it is just replacing components it shouldn't be expensive, but , bare in mind, more elaborate work could be more expensive than controller (you'll just have to check it out). Hope that "malfunction" can be solved.
