You have to cover the spokes on both sides with the fiber washers to protect them if you don't
then your spokes will soon be toast.
proper way to install the rear sprocket
like building a sandwich
starting on the out side
sprocket
fiber washer
spokes
fiber washer this one needs to be cut only so you can get it over the axle.
metal backing plates
bolts need to be installed with the bolts head on the sprocket.
Nuts, washer, lock washers are on the inside of the wheel.
sprocket
fiber washer
spokes
