Trying to figure out what type of piping I need to build an exhaust system.
Will electrical conduit work?
I do have a welder – though I have never used it yet  Seems like as good a project as any to learn on!!
Thanks!
Thanks!
Hi Tron,
I used 3/4 inch electrical conduit for the exhaust on a Schwinn OCC. Works fine. I cut off the mountin g flange from an old exhaust pipe and welded it to the conduit. Then I used high temp paint so you can't tell it is conduit
Jim
How do u make that Squar in your sentence"I have never used it yet."
 ) it turned into the box after I posted it.
 ) it turned into the box after I posted it.Didn't mean to. LOL
Out of habit, I made a smiley face out of a colon : and a close parenthesis ) . When I put them together () it turned into the box after I posted it.
I saw the icons at the bottom after posting... I will figure things out.. eventually.
-Tron
Tried conduit and it works O.K., actually bicycle handle bars seem to be stronger. We've cut sections from different handle bars to mock up our special bends and added expansion chambers in line. Mark with a felt tip sharpy on where we've adjusted the pieces exactly right- and tack weld them together. Then put entire pipe on a table and complete the welds.
Also, I ficured I could use a pipe bender and shape the conduit and do less welding.
-Tron
Hey Russel, is that a mechanical speedometer on that chopper? If so, how long has it lasted? I just got one and am a little curious what to expect.
