bizcotch
The RAW engines run really good with the stock jet size... But if you want to lean it one size, go to #71 drill bit.
Thanks. I soldered and drilled two extra jets i had with bit #71 and #72. So far i like #72
.The RAW engines run really good with the stock jet size... But if you want to lean it one size, go to #71 drill bit.
.Thanks. I soldered and drilled two extra jets i had with bit #71 and #72. So far i like #72.
