bills money pit
Howdy!
I have many questions and observations concerning the kit I purchased from
Revolution,
Revolution,
hi bill and welcome to the site. your bicycle motor carburetor has an idle screw and you should be able to get it to idle using that. i know i had to do a lot of fiddling with mine to get it right. glad to have you with us
Hey Bill, welcome to the forum. Lots of motorized bicycle enthusiasts here. What part of OK are you from. I live in the Texas panhandle so I'm real close to OK. Post some pics of your build. We'd like to see it. Glad you joined us....................
There is no mixture screw that Is the idle screw... run it in all the way then back out four and a half turns as a starting point.
All the chrome clutch levers are junk in my opinion. I use a brake lever and have never had a problem.
All the tensioners are dangerous. I have had two different ones. Now I have the rear wheel adjusted for the engine chain and the tensioner on the less used bike pedal chain. I haven't had a problem since.
I don't think too many of the kit suppliers are actually bike builders so they pretty much can't help even if they wanted to.
All the kit chains stretch they will stop after about a hundred miles on the bike.
Can't help you with the frame mine doesn't have any suspension at all. One of my many mistakes.
This is the idel screw....In to raise the idel....out to lower idel
To change the air/fuel mixture...you have to change the clip on the needle jet... You will have to pull your carb off and take it apart....Thier is a post somewhere here how to do it.
Is this the bike you are talking about ???
Thats it, thanks for taking the time to find it. It should make a great motorized bike.![]()
http://motorbicycling.com/f25/ezrs-full-suspension-summer-project-1286.html
Ahhh, that's another easy rider the same as the first pic I posted. If I remember right, he spent a while looking for the right frame. I had a double suspension bike but I built mine.
Their is the link above, ask Easy Rider about the frame, I'm sure he would be more then happy to answer any questions you might have.
Welcome to the group Bill. Looks like we'll have another cool suspention bike in the mix. Enjoy the ride...Kelly![]()
