I went back through and read all the posts:
The magneto coil is incredibly simple. Norman and I have both dismantled a coil to gain first hand knowledge of what's going on. It wasn't really necessary, but mechanics want to know.
The simple fact is that there is a 300 turn coil wound around the laminated frame. The white wire is connected to this 300 turn coil. This coil ofers a small current that will power a light...Done, dinghy, diddly...nothing more complicated to add.
There is a second coil that is wound around the first...It is 3,600 turns. The blue wire is connected to one end of this coil. The blue wire is connected to the CDI.
The opposite end of each of these coils, (the end that is not connected to either the blue or white wire), is attached to the laminated frame, (the part the coils are wound around),or ground.
It is best to connect one of your kill switch wires to the white wire, the other to ground.
The reasoning is simple...If you connect one of the leads from the kill switch to the blue wire, you risk a static discharge through the CDI. I know this is unlikely, but considering that both the blue and white wire coils share a common ground...common sense says use the white wire for your kill switch.
Yes you can connect a light and the kill switch to the white wire. It will not do a nuclear meltdown when you hit the kill switch, I promise.
Now; with this newfound bit of knowledge we can delve into why the use of the white wire coil for lighting has caused some to loose spark.
The white wire coil and the blue wire coil share the same ground. A light that draws more current than the white wire coil can produce, essentially becomes a kill switch with a built-in resistor, (the light filament). Due to the fact that both coils share the same ground, an overload of the white wire coil affects the blue wire coil...less out put from the blue wire coil = a weaker spark.
It's simple, don't exceed the output capacity of the white wire coil.
Norman's light kit works great! I put one on the last bike I did.
Jim
