i googled it and found varied results, from running it super hard to idling it, what is the best way to break in a 49cc 4 stroke? thankyou,
i figured, but riding it hard sounded bad to, i broke my 2 stroke in by running it super rich(13:1) and running it smoothly and slowly for 500kms, but this is a 4 stroke, so whats different?Idling definitely isn't the way to go. Engines get the least amount of lubrication at idle.
don't let it idle long and vary the throttle (I never felt any difference like when a 2stroke was broke-in)
agreed with the oil changes...
I changed mine every 100 miles till 500, then every 250
gonna do my 2750 mile change today
The Titan is a 4 stroke 50cc motor. Break in is around 250 miles or 10 hours of operation. Holds only around 8oz of Valvoline conventional motor oil. During break in, be nice and do not ride full throttle for extended periods of time. Be nice and throttle up and down varying engine speed often. Once break in time or miles is achieved, you must change the oil and check valve clearance. The oil will have a lot of glitter in it from break in and must be changed. Since there is no filter and does not hold much oil, check oil frequently and change it when it gets dirty. A quart of Valvoline 10w-30 or 10w-40 conventional motor oil is the oil to use and is good for 4ea oil changes. Synthetic oil is not recommended. Also, Valve clearance must be checked and valves must be adjusted in needed. Both of these are requirements to keep the 2 year warranty valid. After the oil change and valve check is done, then only requirement is to keep clean oil in the crankcase and also check valves again in 500 miles. After that, valve check and or adjustments only needs to be made once every 2000 miles or once every 2 years which ever comes first. So.. To sum it up.. You need to properly break in the motor, and change oil and check valve clearance. This is typical of any high performance 4 stroke engine with adjustable rockers or shims. The Titan has Adjustable rockers which are screw type and super easy to check and adjust. clearance should be .05mm cold. If these rules are observed, the Titan Engine should last forever. The Titan motor is that good !! Enjoy the ride !!
well i have to? it wont run with the choke off, it bogs and stalls, but think about it, if the carb is tuned way to lean then with me choking it it should bring it back to normal mixture, besides i put 100kms on it so far and it runs mint! what else am i supposed to do?You shouldn't EVER ride with the choke on, especially during break-in. If you run the engine rich enough you're washing the oil off the cylinder walls.
