thatsdax
Well today was a break through day for me. I bought a Honda GXH50 some time ago to Test against the Titan XC50. Problem was, I had no way , no affordable way to mount and test the GXH50. The Honda is just not configured to install as easily as the Titan. But today, that changed... I met up with Bandit who just so happens has a Honda GXH50 Mounted to the Dimension edge FD system..... I am Running a TITAN XC50 with a DAX Proto type FD. Bandit rode south, I rode north about 11 miles, and we met at the intersection of Kipling and Morrison Highway. Michael is super and owns a super nice ride to be sure. Honda GXH50 with Alloy Dimension Edge FD that uses Roller Skate wheel type drive to pinch the tire using a lever. He carries with him several size rollers. His bike is a All Aluminum Mongoose with Front suspension. I was riding a CA520 Firmstrong Stretched all steel bike with the DAX all Steel Proto Type Friction drive that uses a Diamond Cut Steel Roller. We swapped bikes and took off towards the Golf course a mile or so up the road. As I pedal the bike to speed, I lowered the Dimension edge system down on to the tire by using a Large Shifter type clutch lever arm mounted to the Goose. Once lowered, there is a direct connect between the motor and the back tire via urethane pinch roller. Using a thumb throttle, I applied power and the Honda felt good and my first impression was that this Honda felt like it made good torque, maybe more than my Titan.. It felt good for sure. The Titan XC50 using the DAX FD is all automatic. Twist and go. So.. We have two different approaches to power delivery. ..... So....As I slowed down to look for Bandit, He finally caught up and said he had to stop because his hat went flying !! I said.. Lets swap back now.. And make a test.. A drag race !! Your Honda against My Titan !! He said. ok !! Lets do it !! And.. So.. We had 2 semi drags. Since the dimension edge can not start from a stop with out pedaling, we had to get up to a speed that would enable Bandit to engage his motor to the tire, at that point which was a fast walking speed or jogging pace, we then throttled up to full.. And let her rip !! Here are the results... Both times.. Honda and Titan were dead even on acceleration and torque. Eventually we would top out. It was at this point That the TITAN would pull ahead at maybe 1-2 mph faster on the Top end. Both Times, I would eventually begin to pull away on the Top. Being that the Titan would pull away with top speed could be attributed to just about anything. Since we are talking, 1-2 mph higher speed. Could be tire pressure, roller size, tire size, there are many variables here to consider. But.. No matter how slight.. I did pull away and keep pulling away, no matter how slight. So.. I would like to thank Bandit for this comparison between Honda and Titan, and drive systems as well. There are so many variations out there. The Weather was beautiful, and the company was outstanding !! Enjoy the ride !!!
