cory151
Im running the tiny tach on my S6S Morini, so I can see where my clutch gives me full lock as well as giving me the ability to track performance in relation to RPM (and hours of use).
It comes set to 360 degrees yet the instructions say that most single cylinder engines idle between 1400-1600 RPM. I basically adjusted my Tiny tach until I got that RPM on the LCD which turned out to be 120 degrees. Is this correct? I want to make sure this thing is reading correctly.
Tiny-Tach: Gasoline Tachometers
.........360.......
