DanielMaia
[Lots of photos now!] Re-assembly 60cc -Low power [solved(base cyl. gasket leakage)]
Hi there guys,
My first motor, 60cc, has broken the piston rings, and i opened it up, installed new bearings SKF, polished and port matched the transfers ports, installed a new base cylinder gasket, a new head gasket, installed all with stock exhaust, and stock carburetor.
The thing is: the idle is near the perfect (not really perfect) but is very constant and smooth. The problem is very simple, a tremendous lost of power. In idle it revs more or less, but in the road (with shift kit installed), it has lots of LOW power. it doesnt bog, it doesnt die, but revs very very slowly, what you guys think?
My misture ratio is 5%.
Other thing, i think the engine is very very hot when i take a ride of 1 or 2km.. (430F i measured on spark plug)
Thank you,
Daniel Maia
Hi there guys,
Thank you,
Daniel Maia
