bairdco
a guy who makes cool bikes
i've seen lots of threads about people's bike's bogging at WOT (Wide Open Throttle) and i'm pretty sure i figured it out.
what i'm talking about is when you're flat out, then it feels like your bike's stalling out or sputtering, then if you let off the throttle for a few seconds it picks back up.
most people suggest changing the needle clip setting, re-jetting, float setting, fuel mixture, or whatever, but i think the real problem is fuel delivery.
basically, the engine's using more fuel than it can get, so it's sucking the carb dry.
the culprit is the stock petcock.
in my kits, the petcock is either the cheap little brass one, or the even cheaper silver one. the fuel outlet on them both is like 1/16", while the carb inlet is 1/8" on some, and 1/4" on others. (i'm talking "Inner Dimension" or "ID.")
if you take the fuel line off the carb and watch the flow of gas that comes out with the petcock on, (and obviously into an approved container) you'll see it dribble slowly out. that's fine to keep the bike running, but not enough at high speed, when it needs more.
after i rebuilt the engine on my fastest bike, it started bogging at top speed. it was still going fast, but i didn't like being in traffic with the engine cutting in and out, so i went through the whole fuel system, checked the tank, the filter, changed the fuel line, and it still did it.
but when i went over everything, the stock petcock started leaking, so i switched it out with a Tecumseh, 1/8" NPT petcock that i use on my custom tanks.
the problem went away completely, and it's been about 2 months.
you will need to buy a 1/8"NPT (National Pipe Thread) tap for your tank, though, because the stock petcock's have straight cut threads, but you don't have to re-drill the tank or anything. the hole is the right size for the tap.
then just install a good quality petcock (lawnmower shops have good ones for cheap, and so does ebay) and you're set.
while you're at it, get rid of that cheap plastic tube and get some real fuel line...
