Worksman Boardtracker on Ebay
yea these are nice builds and it looks like they have sold 2-3 already at $1600-$2000 each. That's some nice profit especially if they have figured out how to mold the tanks out of a gas proof plastic material. Also, a couple of them had the back fabricated oil/tool box. I like what they have done with the forks on this one though!
I like the first indian. The second would look so much better with color coded guards. And what the **** is that above the cranks and below the seat?
If you'd like to see his website just click on the Link Below.
Deuce Custom Bicycles - any way you want it
George, had been making these Tribute Board Track Racer's prior to working with cinelliphyle, it was cinelliphyle who suggested modifying the Worksman Inb's frame with a Drop Loop & it was as far as I know it was cinelliphyle who did all the painting and cinelliphyle also made the gas tanks both the torpedo Cyclone style & rectangular Harley style!
As far as I know George learned how to ( modify / Drop Loop frame ) build these Worksman Industrial Newsboy Tribute Board Track Racer's from none other than our fellow forum member cinelliphyle!
George, is a great guy and was formerly in Washington State before relocating to Florida, having been an employee at the Boeing plant he had access to the old surplus Worksman Inb's that Boeing was was throwing away and or selling and he stocked up.
See these related posts below!
http://motorbicycling.com/f38/real-worksman-drop-loop-tribute-board-18260.html
http://motorbicycling.com/f38/custom-harley-davidson-track-board-bike-11480.html
http://motorbicycling.com/f38/side-car-13650.html
http://motorbicycling.com/f38/worksman-drop-loop-frame-btr-17244.html
This post is to offer information about these builds only!
Both George & Rick are awesome people who have shared their builds for the enjoyment of all!
C.H.
Other Makes : Custom | eBay
Nice build and at 2000.00 the first day...
he also has this bike listed.
Custom Built Motorcycles : Racer | eBay
it says in the adds that the tanks are ABS, which i assume meens there made of plastic. wonder how he did that and who he is.
72tx340 & camlifter, Referencing Duece Motor Bicycles Tribute Board Track Racers listed in quote above and posted on ebay for sale.
The tanks according to Rick Gilmore are pvc plastic pipe that is then fiberglass molded to either a Harley rectangular style tank not unlike sportscarpats gas tanks which are steel but similar in design & the other is an Indian & Cyclone style torpedo / cylinder gas tank!
Indian Board Track Racer torpedo / cylinder style gas tank below.
Harley Road style gas tank on a Worksman M2300 Industrial Bicycle below.
Harley & Excelsior-Henderson Board Track Racer style gas tank.
Seattleriders, Harley Tribute Board Track Racer, same gas tank as Excelsior-Henderson just different branded graphics!
I cannot confirm if Rick & George are still building these bikes together or if George is building them himself now in Florida.
For more information about these builds above contact George@ Deuce Custom Bicycles - any way you want it
contact Rick@
VROOMART.COM
Peace C.H.
P.S. Support our forum members with that being said if you like the builds above you'll be blown when you've seen fellow forum member sportscarpats Worksman Industrial Newsboy's built out to a Sportsman Flyer or Sportsman Racer see links below! Contact sportscarpat by private message here at Motorbicycling.com
http://motorbicycling.com/f38/sportsman-flyer-drop-loop-boardie-kits-22814.html
http://motorbicycling.com/f38/board-track-racing-kit-19338.html
http://motorbicycling.com/f38/worksman-boardtracker-15883.html
http://motorbicycling.com/f3/worksman-frame-tanks-15508.html
http://motorbicycling.com/f8/whizzer-powered-btr-25810.html
http://motorbicycling.com/f38/sportsman-racer-latest-photos-26177.html
http://motorbicycling.com/f38/boardtrack-racing-handlebars-13488.html
http://motorbicycling.com/f38/frame-boardtrack-gas-tanks-13483.html
I was wondering about the tank as well. Looke correct as well. I think the oil tank is being used as the gas tank. But the feed would be below the carb so that wouldnt work.
Just found this one today on ebay.
It appears that one of our fellow forum members is selling his build!
Board Track Racer Bicycle Motorized Flat Tracker Bike
Here's the Link below.
Board Track Racer Bicycle Motorized Flat Tracker Bike | eBay
Short clip of it running around
YouTube - Board Track Replica
A link to a build thread
http://motorbicycling.com/f38/short-tracker-2-0-a-13485.html
Item Description.
This is a sad day but I’m moving and my wife said either this goes or my Triumph project. I run a small hotrod/ chopper shop and this was my screw around personal project for the last 3 years. I started with a early post war Cleveland Welding frame, best guess would be 1947-1948. Put a Monark reproduction springer front end that has been completely re welded and added a lever shock. The gooseneck and handle bars are early Schwinn. Wheels are industrial Worksman with a drum brake front (which is not currently hooked up) and coaster rear wrapped with felt quick brick tires with Kevlar rim strips and “Slim” inner tubes and a Manic Mechanic billet drive sprocket adapter with 40 tooth sprocket. The seat position has been moved back by adding a new seat post, all modifications on the frame have been brazed not welded to keep it “bicycle strong”. the tank is made of steel and 100% custom and doesn’t leak a drop. The back half of the tank is hollow to house the CDI and keyed kill switch. So now onto the engine, it started life as a Grubee GT5 66cc but now it has a Rock Solid billet head, thin head gasket, completely ported jug, upgraded lower bearing, anti friction coated piston with a modified skirt to eliminate it from shrouding the intake port at TDC, rewired mag with automotive grade wire, ported aluminum intake with a single Boost bottle the exhaust is a Spookytooth expansion chamber with a SBP muffler welded on with a 2“ turn out and heat wrapped with Thermo Tech copper exhaust wrap. I just recently got it running and it has tons of power for it’s size and with the 40 tooth gear it passes traffic at 40ish without pushing it hard. Please understand you need skill and riding experience to ride this, IT IS FAST. I’m sure I missed something so please don’t hesitate to ask me a question. Buyer is responsible for all shipping arrangements and cost. Located in Vista CA 92084
If you have found anything similar or related to Tribute Motorized Bicycles please share it here with the forum!
C.H.
Check this out, and anyone that can loan me about $50,000 US-Dollars I'd be most appreciative.
Here's the Link 1910 Indian Blue Board Track Racer on ebay.
Indian : 1910 Single Racer | eBay
And here's the 1914 Indian Red Board Track Racer also on ebay.
Indian : Twin Racer | eBay
Checkout the pic's below!
And for those of us who don't have this kind of spending money for an original Indian, all I can say is thank god for sportscarpat and his sportsmanflyer's!
C.H.
