Just found this one today on ebay.
It appears that one of our fellow forum members is selling his build!
Board Track Racer Bicycle Motorized Flat Tracker Bike
Here's the Link below.
Board Track Racer Bicycle Motorized Flat Tracker Bike | eBay
Short clip of it running around
YouTube - Board Track Replica
A link to a build thread
http://motorbicycling.com/f38/short-tracker-2-0-a-13485.html
Item Description.
This is a sad day but I’m moving and my wife said either this goes or my Triumph project. I run a small hotrod/ chopper shop and this was my screw around personal project for the last 3 years. I started with a early post war Cleveland Welding frame, best guess would be 1947-1948. Put a Monark reproduction springer front end that has been completely re welded and added a lever shock. The gooseneck and handle bars are early Schwinn. Wheels are industrial Worksman with a drum brake front (which is not currently hooked up) and coaster rear wrapped with felt quick brick tires with Kevlar rim strips and “Slim” inner tubes and a Manic Mechanic billet drive sprocket adapter with 40 tooth sprocket. The seat position has been moved back by adding a new seat post, all modifications on the frame have been brazed not welded to keep it “bicycle strong”. the tank is made of steel and 100% custom and doesn’t leak a drop. The back half of the tank is hollow to house the CDI and keyed kill switch. So now onto the engine, it started life as a Grubee GT5 66cc but now it has a Rock Solid billet head, thin head gasket, completely ported jug, upgraded lower bearing, anti friction coated piston with a modified skirt to eliminate it from shrouding the intake port at TDC, rewired mag with automotive grade wire, ported aluminum intake with a single Boost bottle the exhaust is a Spookytooth expansion chamber with a SBP muffler welded on with a 2“ turn out and heat wrapped with Thermo Tech copper exhaust wrap. I just recently got it running and it has tons of power for it’s size and with the 40 tooth gear it passes traffic at 40ish without pushing it hard. Please understand you need skill and riding experience to ride this, IT IS FAST. I’m sure I missed something so please don’t hesitate to ask me a question. Buyer is responsible for all shipping arrangements and cost. Located in Vista CA 92084
If you have found anything similar or related to Tribute Motorized Bicycles please share it here with the forum!
C.H.
