rohmell
I picked up a bike at a yard sale for ten bucks. It is an 18 speed with 24 inch wheels.
The tires are 24 X 2.1, some Chinese brand.
When I bought it, both front and rear inner tube valve stems were at an angle instead of straight up in the rim.
I though that maybe the previous owner messed around with the tubes and tires, so I took it all apart, cleaned the rims, strips, tubes and tires (everything was clean, anyway) and reassembled everything.
I rode it around a few blocks and noticed that the front valve stem was at an angle again.
I took the front apart and the valve stem came out of the original inner tube. OK, defective, so I replaced it with a Bell self-sealing inner tube that is designed for use with 1.75 - 2.25 tires.
Went riding a few blocks and PFFT the front tire goes flat and self-sealing goo is all over the place. I took it apart, and the valve stem came out of the inner tube (again?)
Replaced it AGAIN with a a Bell self-sealing inner tube that is designed for use with 1.75 - 2.25 tires. Went riding a few blocks and the valve stem on the front tube is at an angle AGAIN!
WTF is going on?
Stock factory wheels, stock factory tires, same brand and type of tire on both front and rear, and the rear rim is not doing the funny valve stem angle thing, although when I first got it, the rear was at an angle, too.
I use the Bell self-sealing tubes on all of my other bikes and builds in 20" and 24" sizes and have never had this problem.
This is the tube that I am using, from Wal*Mart:
Walmart.com: Bell Bicycle Self-Sealing Tube, 24": Bikes & Riding Toys
WTF is going on?
