1: Tanaka didn't make the bikebug engine, Sears did. 2: I have heard of in-frame engines being mounted rack-style. What I imagine it being like is pretty much this, although I could be wrong. Even if I am wrong, it could probably work this way. You would need whatever hardware is necessary to mount a friction drive engine. You would also need The chopper mounting plate used to mount in frame engines on chopper bicycles. You would have to be very skilled or very lucky to get this right, because you probably only get one shot. if you can figure out how to put everything together so that the chain lines up correctly, you could weld the chopper mounting plate to the friction drive mounting hardware, then just bolt the engine on and attach the friction mounting hardware to the frame of the bike. or, you could just drill through and bolt the mounting plates together. probably better this way, because if you mess up, you can just drill in a different spot until you get everything lined up correctly.
