ok I didn't report back for awhile because no one seemed that interested anymore. but I have a report as well as an update. the way I had the pipe put together and installed wasn't working so I took it apart. I know I didnr do it right because I was able to take it apart with my bare hands. I was going to use sheet metal and hose clamps to put it back together, but then I saw a fiberglass kit at walmart for around 12 bucks and I grabbed it. the kit included 8 ounces of resin, a small tube of hardener, a square yard of cloth, a mixing tray, a mixing stick and a spreader. I reassembled the pipe using fiberglass and now its solid. my muffler rests against the top of my rear chainstay, so I attached a muffler strap that is clamped around the muffler and my seat tube. its basically just for extra weight support sine I don't know what kind of vibration and bumps the fiberglass can handle. now to report the performance of the pipe. with my last muffler my top speed on flat ground was 23 and uphill was about 13 or 14. I at first didn't see a difference with the pocketbike pipe, but I chalk it up to not having it assembled properly and not having the engine tuned for the pipe. since figuring out how to tune the engine for this pipe, my top speed on flat ground has increased from 22 to 28 and uphil from 13 or 14 to at least 18 and in some cases as much as 20. the pocket bike pipe has an extremely short header, so I lengthened it by starting with the header from the stock muffler and then adding another two inches or so that was cut from the tailpipe of the pocketbike pipe. I took some sheet metal and rolled it up inside the sections of pipe to fit them together before fiberglassing. I just had the bike out for over an hour today with no problems. as far as tuning the engine, I leaned the throttle needle out the whole way and I'm running a 25:1 mixture. the spark plug is a nice brown color which is basically a cross between mud and rust. before I leaned the needle out it was black and my head was leaking oil. no more oil leaks now. as far as the idle screw, it is currently set to 4 and 1/2 turns out. I run a 68.5cc engine purchased from luckyearlybird on ebay. I also have the upgraded exhaust gasket. my bike runs better than I could ask for considering it pulls my 290 lb butt around at 28mph on a beach cruiser lol.
