B bob1352 New Member Aug 15, 2017 14 0 1 25 Oct 4, 2017 #1 The bucking bar on my bike was bad. Being a novice machinst I need to know the length and diameter of the bar so I can make it. The bar tends to have a lose fit so I am just looking for a ballpark figure for a standard 2 stroke engine.
el Diablo Guapo Member Nov 27, 2013 143 4 18 earth www.Frankenbikes.com Oct 4, 2017 #2 since i have mine out... inches: 1.048 x.3125 or ~1 1/16 x 5/16 mm: 7.93 x 26.82 (~8 x 27) el
crassius Well-Known Member Sep 30, 2012 4,032 156 63 USA Oct 5, 2017 #3 1 - bucking bar should last pretty much forever 2 - bucking bar should not be a very loose fit in shaft I'm guessing you failed to keep enough grease on it, so should look closely at the shaft to see if a new shaft is needed too.
