maniac57
Okay guys, I'm at a loss here...
The last two days, my bike has been acting very strange. It runs fine for about ten minutes, then begins overheating so badly it refuses to cut off when the kill switch is pressed! It loses power and sounds like the muffler is clogged! (it's not) The cylinder gets hotter than the exhaust!
Nothing was touched prior to this problem and it was running great before now.
I've changed the plug,swapped the head (no difference) the plug wire, disconnected the kill, checked the stator key (good) swapped the cdi and also the mag coil with no change.
The head looked fine with no strange buildup or anything that would cause a hot spot leading to pre-ignition, yet it actually diesels with no spark once it starts acting up.
I pulled the plug wire and rode it another mile today before it finally died!
I'm stumped. Like I said, the mag stator key is not sheared or damaged so I can see no reason for this. Everything in the engine LOOKS fine. What else could affect timing so badly?
What am I missing?
This is the first air cooled two stroke I have ever seen that was overheating without MAJOR timing issues or mechanical damage.
HELP!
What am I missing?
HELP!
