Well, I have finished transplanting my engine kit onto my new bike, it looks absolutly awesome! I decided to remove the front derailer so that the engine mounts properly... thanks for the tip! I still have a few problems. First thing first. I mounted the chain tensioner on the bike and found that the bottom tube is too small, I decided to add some metal shims under the bracket to see if it would make up for the difference, it seems to work... kinda. The problem is that when I fired up the engine the chain pulled the tensioner and bracket into the wheel and seriously bent 4 of my spokes. I have a few ideas of why this may have happened:
1. Chain tensioner wheel is worn out and sliding around too much.
2. I noticed that the bottom bars are at quite a bit of an angle which caused the chain to grab the edge of the tensioner wheel and throw the tensioner assembly into the wheel.
3. The main engine sprocket and the wheel sprocket do not line up, it seems that the wheel sprocket sticks out farther than the engine sprocket.
4. Although I have added the metal shims to the mounting bracket and I can barely move the assembly with my hand, the engine has so much torque that the chain just pushes down on the tensioner wheel and flips it into the bicycle wheel.
My second question is... what do I do about my bent spokes? I would rather not bring it into the bicycle shop to get fixed because I want to learn how to do it myself.
I am at a loss on how to fix these issues, maybe someone can point me in the right direction as how to fix these.
Thanks,
Ben
