cannonball2
This might should be in the Ebike section but not much seems to go on there.
We just bought a 120yr old house to work on as a hobby. This old yard trailer was left there. Was going to yard sale it when I remembered a Schwinn step thru frame in the attic at home. We'll the wheels began to turn and this is what happened. It's in the rough out stage. Will need a bit of reinforcement. Had to weld the bed to the tongue and the frame to the bed to make it rigid eliminating the dump feature, I wouldn't have used it anyway. This is basically it.
There is a good bit of acerage at the new place and this will work as a gofer. Will use a 9C hub motor on 48v. If it works as expected may down the line extend the axles and run 24" trike wheels outside the bed. Add a little wood trim to the bed etc. Should be useful if nothing else. Expected a top speed in the low twenties. About as fast as I want to go on a trike.
