When it comes time to install the new rings you'll need to be very careful and not break them. They aren't made of rubber and will only stretch so far to go over the piston. Go slow and carefully work them on in a circular motion into the ring grooves.
There are ring gap alignment pins in the piston ring grooves. The gaps of the rings must align with those pins or the rings can not be compressed enough to slide back into the cylinder bore. Lubricate everything, rings, piston and cylinder with whatever oil you use in your fuel mix before reassembly.
My concern is that if you had broken rings that there is damage to the cylinder walls. It would be rare that the rings would break when the engine is running and there not be damage to the cylinder. Inspect the cylinder walls for gouges. A damaged cylinder will not allow the new rings to seal and you'll be back to square one and will have wasted you money and time buying new piston rings.
Just curious here, but how slow are you trying to ride the bike with the clutch engaged?Rings have been installed! No luck with fixing my issue though :/ Plug still comes out oily and black-ish even on leanest settings possible for the carb. It ran choppy for a minute, then just fine for another minute, then it boggged and died. My bike idles just fine but as soon as it gets moving it jerks violently and won't idle anymore. Choke completely kills it and my idle screw has to be screwed almost all the way in.
From your description it almost sounds as if you're trying to idle along. That won't work. Anything below 8 to 10 mph and the clutch should be disengaged.
Or am I reading your last post wrong?
Did you retighten the head bolts after break in? if engine is oily with low mixture it could be an engine leak causing both problems. only suggesting because you mentioned not messing with the engine. could be wrong but I think proper torque is around 12lbs for the head bolts?
My carb appears to be in perfect condition. It's pretty much brand new too :/
Put a NGK B7HS in and gap it @ .028 and you reallllllyyyyyy roll.
