mew905
So upon chatting with some guys in the Facebook group Motorized Bicycle Gallery, someone has tried the titanium wrist pin, and with disastrous results. Apparently the piston wore through it rather quickly, and when the motor heats up, the aluminum expands at 4x the rate the titanium does! That means mean your motor is toasty warm and ready to go, that pin is barely holding on.  Apparently the wobble got so bad the piston caught a transfer and ripped a good chunk of the wall off (he provided pictures).
So the verdict: as good as it may sound, do not use the titanium wrist pin or risk catastrophic damage to your engine. Sorry Juice Moto, looks like we gotta lighten up our pistons another way (Reeds, balance, true and bearings are your only options to reduce vibrations, sadly, reeds will have the biggest effect making your sweet spot much longer and higher up in the range, balance will have a good effect but only move your sweet spot, does not make it longer. Truing is tricky and possibly give you minor results, giving you a smoother bike throughout the whole RPM range, and bearings will give you the most insignificant results, again through the whole range. Moped pistons weigh more than our pistons, bushings weigh slightly less, and the only other option is material removal from either the piston or the wrist pin.
