maniac57
Use strips of aluminum to shim the hub to fit tightly in the sprocket center hole. Assemble the ragjoint and then insert shims as needed before tightening the bolts. This holds everything nice and centered so there are no tight spots in the chain. Removing any play will make the kit ragjoint work correctly and avoid driveline problems down the road.
