Is all I heard after removing my clutch cover? (right side of china girl). The reason I took it off was that when I fixed my chain from on a sprocket upgrade I took her out for a test, at first had trouble starting to the point I had been o check for spark by removing the plug and placing on the head, got spark so I dipped it in my tank then screwed it in, fired up went around the block fine. Went to wash my hands came out went to go for a real ride and no start. I let go of the clutch and I kept going, its acting like the clutch is disengaged, took it back home checked the clutch I still got tension and works fine everything looks normal, removed other cover described above that's when I heard tink tink, but with out taking everything apart everything looks normal, and I didn't see what it was
